Won't Charge Till Redline
From Vancouver BC Canada
My car wont charge until I rev up the engine to unreasonable RPMs. Everything bumps up in voltage, then it overcharges... But at least it doesn't die.
Curious...?
Posted on: 2008/12/13 19:57
If at first you don't succeed, lower your standards.
Keith (Mac-Datty)
Re: Won't Charge Till Redline
Bad wiring is the most common cause for this type of problem. First check the belt tension (1/2 inch deflection is spec). If the belt tension is correct, suspect the alternator brushes, which are only about $5.
To test the alternator, touch F wire to BAT+. Even at idle it should rise above 12V. Spec is about 13.5-14.5 volts. If this works, problem is in the external wiring or a bad regulator.
Posted on: 2008/12/13 20:29
