Brakes getting jammed
From Malaysia
Hi, I have a problem on my B310 front brakes. The front brakes seems to work fine, but the problem is that the front right side is not getting released after i have released the pedal. Well, it doesnt get jammed completely, you can still jack the wheel up and rotate the wheel, but with lots of effort. Because the caliper is not releasing the brakes, the disc eventually gets super hot when driven abt 5km. This leads to brake failure, with lots of smell and smoke ( from burning pads ) from my front right side.
I have serviced both the calipers ( left + right ), changed the piston seals..O-rings..etc. There's no leak in the master pump. The brake fluid level does not go down, meaning that there's no leak. There's no bent or dent on the brake lines. But im still facing the same problem.
Any solutions?..thank u
Posted on: 2008/12/16 4:53
Re: Brakes getting jammed
From Nyngan, nsw Australia
maybe give the brake lines a blowout mite have pickup a bit of dirt?
could be stopping it from returning maybe, im sure there be sumone on here will nut it out
Posted on: 2008/12/16 5:06
living is good,.....
From Adelaide
I'm assuming the callipers are working correctly and the piston can return into the bore when the pressure is released.
One possibility is a separation inside the flexible brake hose.
This can occur on old hoses.
The layers separate and crate a crude "one way valve" inside the hose.
This allows the fluid to pass into the calliper to apply pressure but closes it off when you release the pedal, thus retaining pressure in the calliper.
Try fitting a new flexible hose to the offending calliper and see if that helps
Posted on: 2008/12/16 5:20
Nissanman - just trying to help...
One problem is a corroded piston, yes it sticks then gets hot and wears the pads out on that side. You can sometimes get the piston to move, but replacing the seals won't fix the problem. So make sure there is the right amount of clearance between pistons and bore (these are double-piston units) and no corrosion in the caliper or on the pistons.
But also common -- especially with Sunny brakes, is the caliper sliding surfaces are sticking. Remove all rust, carefully scrape the sliding surfaces, get it to move firmly but smoothly, and properly lubricate it.
Posted on: 2008/12/16 6:09
From bathurst nsw
i agree with dd, the caliper slides (the pins which the caliper moves in and out on) are sticking causing the brakes to drag. in the past week i have had two of these cases happen to cars at work. pull the caliper off and i will bet you you wont be able to pull the caliper slide pins out of the caliper. the easyest fix....get a new one if you cant get it out.
Posted on: 2008/12/16 7:16
My car gets me from A to B...Just faster ;)
From Adelaide, Australia
When you had the brakes off maybe one of the flexible lines was twisted which would cause this to happen.
Posted on: 2008/12/16 7:18
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Malaysia
Thanks for the flexible hose advice, i will try changing that first.
1.) DD, Piston was initially corroded a little, but when i serviced it, i sanded the piston and also the bore. Its clean now. The caliper "sliding" area was also scraped and well lubricated.
2.) WhiteSedan, no twists were found at the brake lines.
3.) Woody, im worried it is the pin, as u said. Well, actually, this problem has occured several times. I have tried solving this problem by a can of WD-40 and knocking & pushin the caliper back n forth. Initially, it will be difficult, gotta use a hammer though. But after a minute later, it becomes easy, can grip it with fingers to move it back n forth. By doin this, it would last for probably 3 days, before the same thing happens again.
What i would like to know is how should i make sure the pins are aligned well and it is not stucked. Please help
Posted on: 2008/12/16 7:59
From perth
if you dont know enough to work this out yourself then you dont know enough to fix it
go to a proffesional brake shop
im all for "have a go yourself" but brakes need to be 100% right the first time
its your ass
dazza
edit : assume that most of the time people on forums dont know S#it. most of the time you will be right
Posted on: 2008/12/17 11:02
From Malaysia
I would say its always a smart move to ask the experts here in this forum before paying a visit to the "money minded" mechanic. it could be a small leak in the brake hose and u'll might end up changing the master pump or the calipers without knowing the actual symptoms. Got my point ??
Posted on: 2008/12/18 12:07
yes, got your point.
The problem is some of the corrosion is still there, the tolerance is too tight now.
1. The parts need to be carefully cleaned to restore the proper gap between the caliper frame/holder and the piston body
2. Proper lubricant applied to prevent further corrosion, and to allow smooth operation
Posted on: 2008/12/18 18:53
