CA bell housing...
From Melbourne AUS
i noticed an add. for a series 3 bluebird with CA20 engine number...
when i inquired the female owner told me it was a 4spd manual...
i didnt know the ca20 came with a 4spd? if this is correct would the bell housing still be suitable for use with an r30 5spd for a ca conversion?
Posted on: 2003/7/12 6:34
1973 B110 A12
Re: CA bell housing...
From Melbourne AUS
bump.....
anyone know?
Posted on: 2003/7/13 11:58
1973 B110 A12
From Warwick, QLD
You can use a CA18DET (S13 silvia) bellhousing witht eh MR30 stumpy 5speed manual, the stumpy box and the CA bellhousong mate and bolt up perfectly. I just did it.
Cheers
Damo
Posted on: 2003/7/13 12:11
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Melbourne AUS
yeah im aware of that.... but i also know that series 3 bluebirds with the CA20 have the same bellhousing... just wondering if the 4spd is the same? thats if there is a 4spd with the ca20?
Posted on: 2003/7/13 12:18
1973 B110 A12
From Wellington New Zealand
There were front wheel drive bluebirds with orible singlecam CA20's in em... I doubt that a bellhousing off one of these will work. Is the series III FWD?
There's at least two different size selector rails in the 71 series boxes, the 3 holes in the front where these slide may give you grief...
There's also a couple of starter motor combinations for CA's...
I'd find a S13 box methinks...
Posted on: 2003/7/14 3:38
From Melbourne AUS
the series 3 is rwd... ill probably end up getting a s13 or 180 box.. but just thought if its the right one i might aswell grab it as its just around the corner from where i live...
Posted on: 2003/7/14 6:00
1973 B110 A12
From brisbane
I have a 5 speed ca20 bell in the shed if you want it mate. No use to me, cost me $50, thats all it means to me.
mely
Posted on: 2003/7/17 3:30
From Melbourne AUS
thanks ill keep it in mind..... see if i cant find one here first.... to save sending it over ...
thanks
Posted on: 2003/7/17 12:09
1973 B110 A12
