Throttle Cable
Not too shy to talk
From Hobart, TAS, Oz
Hi all,
I'm needing to replace the throttle cable in the 1200. Went to the local Burson's and found that they have cables for 1000, 120Y, etc., nothing for 1200.
What would be a good alternative apart from going to the wreckers.
Cheers all,
Kel
Posted on: 2008/12/30 5:31
Re: Throttle Cable
From Tamworth , NSW
why cant you use a 120y cable? they are all just a loop on one end and a lead bead on the other right?
Posted on: 2008/12/30 5:33
Re: Throttle Cable
B210 (120Y) uses the same cable as B110 (Datsun 1200). B310 (Sunny) is different.
Posted on: 2008/12/30 5:49
Re: Throttle Cable
Not too shy to talk
Thanks for the reply, that will do nicely.
I was caught out once with the line of 'yeah mate, this will fit' when I was looking for a bonnet cable...unfortunately didn't fit.
Can't be too sure now can we...
Kel
Posted on: 2008/12/30 7:17
Re: Throttle Cable
In a pinch, you could use twine or a plastic newspaper bundle tie. I've made do with that.
Posted on: 2008/12/30 7:27
