PCV valve on an A12GX - failure anyone??
From Hobart, Tas. Australia
Has anyone had a pcv valve stick or fail on an A12 GX. I've got an uncontrollably high idle - running twin SU's - and even with the butterflies fully closed it idles at 2000.
There has to be an air leak somewhere and the PCV valve seems most likely.
I'm going to try blocking it temporarily just to see what happens.
Posted on: 2003/7/16 4:48
SPITSUN - A12GX powered Triumph Spitfire
View my spitfire on Triumphowners.com
Subject Poster Date
     PCV valve on an A12GX - failure anyone?? britishcarfreak 2003/7/16 4:48
       Re: PCV valve on an A12GX - failure anyone?? lsd 2003/7/16 4:54
         Re: PCV valve on an A12GX - failure anyone?? britishcarfreak 2003/7/16 5:01
           Re: PCV valve on an A12GX - failure anyone?? ddgonzal 2003/7/16 6:37
             Re: PCV valve on an A12GX - failure anyone?? britishcarfreak 2003/7/16 12:32
               Re: PCV valve on an A12GX - failure anyone?? ang94541 2003/7/17 1:18
                 Re: PCV valve on an A12GX - failure anyone?? britishcarfreak 2003/7/21 2:11
                   Re: PCV valve on an A12GX - failure anyone?? ddgonzal 2003/7/21 4:42
                   Re: PCV valve on an A12GX - failure anyone?? britishcarfreak 2003/7/21 7:19
       Re: PCV valve on an A12GX - failure anyone?? Mazda626 2003/7/16 13:08
       Re: PCV valve on an A12GX - failure anyone?? Dodgeman 2003/7/16 14:28
         Re: PCV valve on an A12GX - failure anyone?? bobs1200 2003/7/16 17:02
           Re: PCV valve on an A12GX - failure anyone?? britishcarfreak 2003/7/16 23:03
             Re: PCV valve on an A12GX - failure anyone?? bobs1200 2003/7/17 0:37
               Re: PCV valve on an A12GX - failure anyone?? britishcarfreak 2003/7/17 1:16
       Re: PCV valve on an A12GX - failure anyone?? jaimecidpedro 2003/7/21 5:27
         Re: PCV valve on an A12GX - failure anyone?? rgrinder 2003/7/21 7:09
           Re: PCV valve on an A12GX - failure anyone?? jaimecidpedro 2003/7/22 0:03
             Re: PCV valve on an A12GX - failure anyone?? ddgonzal 2003/7/22 5:20
               Re: PCV valve on an A12GX - failure anyone?? rgrinder 2003/7/22 6:36
                 Re: PCV valve on an A12GX - failure anyone?? dattodude 2003/7/22 7:18
                   Re: PCV valve on an A12GX - failure anyone?? ang94541 2003/7/22 8:40
                     Re: PCV valve on an A12GX - failure anyone?? bobs1200 2003/7/23 1:09
                       Re: PCV valve on an A12GX - failure anyone?? jaimecidpedro 2003/7/24 2:59
                 Re: PCV valve on an A12GX - failure anyone?? jaimecidpedro 2003/7/22 20:43
