« 1 (2) 3 »
Re: CA18DET Ute, she's not so happy
sounds like moisture in exhaust if you dont drive it much, but unlikely after driving for ages and at temp.
Posted on: 2008/12/28 9:53
From Brisbane
I will run it for a lap around the block tomorrow and get her warmed up a little... I was also thinking that there might be a bit of water/coolant sitting in the exhaust. All else fails I am really hopeing there is going to be a mechanic open tomorrow somewhere
Posted on: 2008/12/28 10:15
If you want more inches, stroke it
From Melbourne, Australia
just did head gasket on supafattos car, took at least half an hour of running/driving to clear the water from the exhaust and then it stopped blowing white smoke
Posted on: 2008/12/28 10:24
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Brisbane
If it us driven for a period of time and say it turns out being the head gasket, will driving it make it worse?
Posted on: 2008/12/28 11:42
From perth
do not let it run low on water!
half hour normal driving should clear out all water in exhaust
Posted on: 2008/12/29 5:01
From Brisbane
I finally got my ute sorted out today It was the turbo, and I sent it out to get a quote to fix it and that came back at $1250. Was cheaper for me to buy a new GT2560R Ball bearing 320hp turbo. So I had a local shop put that on for me...
Picked her up this arvo and headed home, turned out that the vacuum line wasnt put onto the waste gate, and yeah the CA give a might kick at 20psi
Sorted that out and it is all good at the moment. The new turbo runs lower boost than the origional did. And just have to get a bit of pipe made up so i can fit the datsun water temperature sender into it as its massive
Posted on: 2009/1/7 10:11
From perth mandurah
do you have many problems with the CA because im thinkin of doin it to my ute and i want it to be reliable and still go pretty fast
Posted on: 2009/2/16 7:16
most reliable motor is a standard motor.... once you start doing mods you start to get reliability issues nearly every time
slot in a standard CA and it should be as reliable as a stock silvia....pretty good
start playing with it and you will get issues
the attraction to CA's is that stock power is big enough that hopefully you dont have to mod it and can still go fast......
but give it 6months and you will get used to the power anyway in any car.... and want more
not many people seem to be runiing stock turbos on CA'S???
Posted on: 2009/2/16 7:23
1200 Coupe Rallycar
From Brisbane
Yeah they are reasonably reliable... But you have to do everything right first time around... Even then everything else around it usually falls apart
Posted on: 2009/2/16 10:40
From perth mandurah
yeah im not goin to need alot of power i get my ls this year so i will just keep it standard
it should be fast enough, i just want it to go faster than a 400 chev, at some piont it would be good
Posted on: 2009/2/16 12:45
« 1 (2) 3 »
