« 1 2 (3) 4 5 »
Re: s13 struts
From malta
what do u mean. when u say the s13 radias rod does not fit. is it too long or too short???
cause i was thinking of using that over my b310
Posted on: 2008/10/30 15:57
Re: s13 struts
From Brisvegas, oz
well i dont know about your 310 but on the 1200s one of the ends that connects to the car is different
Posted on: 2008/10/30 20:17
www.camerasplus.com.au
Re: s13 struts
From malta
and what about the lenght?????? is it the same. even on b310 the end is diferent. but drilling a hole and welding a washer is not a big deal
Posted on: 2008/10/31 16:42
Re: s13 struts
From Brisvegas, oz
i dont know about 310s
Posted on: 2008/10/31 20:21
Re: s13 struts
From malta
in case of a 1200 is it too short or too long. or is it only the way it connects to the chasis
Posted on: 2008/10/31 20:59
Re: s13 struts
From Burpengary
Hey I got some r31 radius rods off another member here, but they seem to be about the same length as the stock 1200 ones... Is there some modification i need to do to them?
Posted on: 2009/1/20 21:26
Re: s13 struts
From malta
u can increse the thread part so that u can get a little bit of caster
Posted on: 2009/1/20 21:35
Re: s13 struts
From Springwood NSW, Formerly Tas.
how do you go about the steering?
this thread is the most useful one ive read about this conversion i reckon.
cheers tom
Posted on: 2009/1/20 23:01
1978 120y Coupe.
Re: s13 struts
anyone?
Posted on: 2009/1/21 9:15
1978 120y Coupe.
Re: s13 struts
From malta
as mentioned by the otherguys you should use the s13 ball joints for the steering. i m still on the process i've never driven it with the new setup so i cant tell you how will it be but judging from the distance between the ball joints it will be nearly the same even a little bit lighter since the distance is bigger.
scientific equation moment = force * distance
keeping the same moment / longer distance = smaller force
Posted on: 2009/1/21 11:46
« 1 2 (3) 4 5 »
