Re: s13 struts
From Springwood NSW, Formerly Tas.
so what your saying is the std 1200 outer tie rod end will still be ok to use? sounds too good to be true
Posted on: 2009/1/21 12:43
1978 120y Coupe.
Re: s13 struts
From Burpengary
well upon further inspection, and removal of my standard radius rods, the r31 rod is longer! I was expecting it to be shorter, is this correct?
The r31 rod is on the right
[img]http://s160.photobucket.com/albums/t177/lowendtheory/?action=view¤t=IMG_0044.jpg[/img]
Posted on: 2009/1/21 15:03
Re: s13 struts
From malta
u have to use same tie rod but you will use s13 tie rod end. (both right side because of their thread)
Posted on: 2009/1/21 16:07
Re: s13 struts
From Burpengary
can anyone shed any light?
Posted on: 2009/1/23 14:05
Re: s13 struts
From malta
what do u mean??
be specific
Posted on: 2009/1/23 21:08
Re: s13 struts
From Burpengary
Is an r31 radius rod longer than a standard datsun 1200 radius rod? or can someone please let me know how long an r31 radius rod is
Posted on: 2009/1/23 22:41
Re: s13 struts
From malta
the image is not shown but if it is longer u can always shorten it.
Posted on: 2009/1/24 15:28
Re: s13 struts
From Burpengary
The point of buying r31 radius rods was that they are 'bolt in' I just want to know if I have the right item. I could have shortened my standard ones, I could of had custom ones made, I did not and do not have the desire to be stuffing around with everything, I just want to know if I have the right bit.
Posted on: 2009/1/25 4:05
Re: s13 struts
From perth
let me get this straight
you have one of each, in your possesion and you want us to tell you which one is longer?
try em and let us know
Posted on: 2009/1/26 3:11
Re: s13 struts
From Brisvegas, oz
the r31 rods are about 27mm shorter from the foward bolt hole centre to the start of the thread
Posted on: 2009/1/26 4:30
www.camerasplus.com.au
« 1 2 3 (4) 5 »
