« 1 (2) 3 »
Re: for sale billet ultra wheels for 1200
From Rosewood, QLD
Posted on: 2009/1/30 5:21
1971 B110 sedan project.
2012 Nissan Micra daily.
From Gold Coast
mine are 5 stud so wont fit urs
Posted on: 2009/1/30 6:35
My 1200 ute project
From brisbane. waking up the neighbours with the brap
pics havebeen sent thanks
Posted on: 2009/1/31 23:23
does anyone know exactly what the standard stud pattern is for a 1200.
Posted on: 2009/2/2 8:24
From northern 'burbs adelaide
4x114.3 or 4.5 inches ... and about a +20 offset
Posted on: 2009/2/2 8:26
im pretty sure you can get a 4 x 4.5 inch pcd 15x7 convo but unsure of the offset
Posted on: 2009/2/2 8:28
From Melbourne, Australia
ya can't just say +20 offset...........
offset is a crappy measure for a simple reason... every time the wheel width changes the required offset changes
there is some good calculators on the net to work out what offset with what rim width is required but you need a starting point, and it's hard to give a starting point because a lot of people have diffrent front suspension set ups in their 1200
Posted on: 2009/2/2 8:32
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
to give an idea i have 15x6 rims with +38mm offset, but i use a 4mm spacer to make them effectively +34mm offset
this suits my 1200 which has stanza struts with LCA's moved out about 10mm and using 195/50/15 tyres, with guards rolled and pumped and the footwell bashed in and the front lip of the quarter cut/bent out of the way.......
so as you can see... there is just too many factors and it becomes a headache
Posted on: 2009/2/2 8:35
1200 Coupe Rallycar
car has standard front breaks and standard rears for ppl wishing to buy wheels... when i get new wheels i will be changing to 5 stud front and running stock wheels on the rear until i have a hilux diff which will get changed to 5 stud aswell thanks for the comments guys
Posted on: 2009/2/2 8:47
bump
Posted on: 2009/2/3 9:17
13b turbo datsun 1200 ute. (WARZ ON)
www.maddat.com.au
« 1 (2) 3 »
