Browsing this Thread:
1 Anonymous Users
L20 drawthrough turbo 45dcoe-jets/info??? |
From VIC, bendigo.
I have a L20 turbo with a drawthrough 45dcoe hanging off the front. it has a nasty flat spot, just off idle. could some one please share some info about jets, emul tubes, etc, for a single weber on an L20 possibly try a Na L20 jets setup for a starting point, just so i can get the thing to rev...then make adj from there. any info is greatly appreciated!
Posted on: 2009/2/2 9:49
1200 Sedan.Turbo A14 drawthrough 15psi Meth inj 104rwkw  1200 coupe club car. turbo L20 drawtrough
Re: L20 drawthrough turbo 45dcoe-jets/info??? |
Is it a new setup or has it been running for some time?
Posted on: 2009/2/2 10:04
From Adelaide, Australia
I can work out some baseline settings for you tonight when I get home.
What jets, chokes etc. are in there now?
Posted on: 2009/2/2 10:08
cheap + fast = disaster fast + reliable = expensive cheap + reliable = stock IPRA Build
From VIC, bendigo.
this is just a new setup, i havnt had it running much, seems to idle fine, but just breaks down/backfires, when the foot it put down, when free reving and under load.
Posted on: 2009/2/2 10:09
Is the carb new?
Posted on: 2009/2/2 10:12
From VIC, bendigo.
my carby has the following.
idle jets : 55/8 emul tubes: F2 airs : 185 mains : 145 a/v : 3.5 chokes : 32 pump jets : 55
carb is not new, i put a kit through it, gaskets, ect im not sure what it is jetted to suit, soo, yeh....
Posted on: 2009/2/2 10:40
From Brisvegas, oz
are you sure your points/spark is good
Posted on: 2009/2/2 10:49
From VIC, bendigo.
yep, sure as sh?t, sorry i should said it "bogs down, and backfires, coz if lean mixture
Posted on: 2009/2/2 11:37
