CA cam gears
From BRISBANE, QLD
Has anyone bought cam gears for the CA and had any dramas or good results? i see alloy ones for sale on ebay and wondered if anyone has bought and used them??
Any recommendations when it comes to adjustable cam timing??
Posted on: 2009/2/23 5:46
Back after a long absence and looking to build a beast starting with a 1974 1200 sedan
Re: CA cam gears
From newcastle
hey mitch thanks for the cooler looks awesome.
yeah had a mate with a set in his 1200 coupe not too sure what brand they were but for the amount of money they are worth (relatively cheap) they are a pretty good bolt on upgrade pretty sure when he had it tuned he gained 10-12 kw just from the gears. dont quote me on that though
Posted on: 2009/2/24 8:29
at first you dont succeed, cut a bit out and put a bigger one in!
85 1200 ute ca18det project build
Re: CA cam gears
From melbourne
hey there be carefull with the ebay gears because i bought a set and the look like they fit and they say there ca but really there rb25det ones the difference is there heaps wider and wont bolt up best thing to do i know its expensive is buy a set of tomei ones! plus you dont wont somethin like that to fail cause in the end you will punch ya valves into ya head if it does fail!
Posted on: 2009/2/24 9:26
Re: CA cam gears
From perth
rb 25/26 one offset
rb30 different again
ca18 another offset
NOT interchangable despite same no of teeth
worth doing but they are expensive
i'm going to make a set for mine
one way to setup is to change timing then do a compression test . max compression is the sweet spot. you need to know your limits either way for piston to valve clearance
dazza
Posted on: 2009/2/24 11:16
Re: CA cam gears
From BRISBANE, QLD
good to hear matt, i hope it all works well for you...
is tomei the only manufacturer that makes CA cam gears tho??
i need to get the motor pumping hard into the turbo which is in reality too big has anyone played with the gears and changing timing?? anyone got some feed back on results?
thanks
rupert
Posted on: 2009/2/24 23:13
Re: CA cam gears
From Adelaide
go on nissan silvia.. and type in the search.. D_stirls
his brother is a CNC machined and they cost 210 change over for your cams..
Posted on: 2009/2/25 1:37
Re: CA cam gears
From BRISBANE, QLD
thanks for that
Posted on: 2009/2/25 1:49
Re: CA cam gears
From BRISBANE, QLD
i have been quoted $400 for Tomei cam gears or $1300 for gears and Cams, anyone nkow if this price is good, bad or otherwise
Posted on: 2009/2/25 8:06
Re: CA cam gears
From Adelaide
400bucks is bout right for just bove retail
Posted on: 2009/2/25 8:26
Re: CA cam gears
From Adelaide
thats the guy that makes the cams for around $220
http://www.growly.com.au/index.html
ill also post the link were his brother talks bout the cams and timing and different cam shafts
http://www.nissansilvia.com/forums/index.php?showtopic=318617&st=0&p=4315367&#entry4315367
heres a read up but his car.. a lot of good info there
[url=http://www.nissansilvia.com/forums/index.php?showtopic=293828
Posted on: 2009/2/25 8:36
