Gearbox speedo drive oil leak
From Brisbane, Narangba
I have a t50 5speed and cant get the speedo drive to stop leaking. Its only just started happening recently. Replaced the o-ring and the cable itself to no avail.
Is there something im missing in the sealing department? The single o-ring doesn't seem like an effective seal for the cable.
My next theory is if the box has a breather? Im assuming so and its blocked because the oil leak only appears after a few days since topping up the box. Thinking its possibly building pressure and exiting via the weakest link.
Any suggestions appreciated.
Cheers
Posted on: 2009/3/16 13:19
Re: Gearbox speedo drive oil leak
Yes, all gearbox I seen have a breather. Should be near the top of the side somewhere.
Older Datsun boxes had a simple bent tube, newer ones have a white round thing over the tube.
The box may be overfilled, what I would do is remove the filler plug and let all the fluid run out.
Posted on: 2009/3/17 3:43
