A12 Internals
From Palmerston North, New Zealand
Does anyone know with of the A12 Engines have lighter crank, rods etc. I know some models do but am unsure which ones and how to tell without stripping the engine. Is it possible to tell from the engine number.
Does anyone know of a 13" steel wheel which has the same stud pattern and off set as a 78 -82 Nissan Sunny but which are lighter than the oringal.
Posted on: 2003/8/6 4:56
Ministock 9p
9p@ministock.co.nz
www.9p.ministock.co.nz
Re: A12 Internals
Kerry, I think no one knows the answer to your questions. I was not even aware that some A12 cranks and rods are lighter than others.
Posted on: 2003/8/7 4:56
Re: A12 Internals
I have pulled apart a few engines and have found them all to be different. Some have steel cranks, some have cast. Some rods are lighter etc.
Posted on: 2003/8/7 5:16
Ministock 9p
9p@ministock.co.nz
Re: A12 Internals
What was discussed here before is that the 1971-1973 A12 engine has forged crank. A15s have cast crank.
Possibly the newer A12s (which were never seen in the USA) have cast cranks.
Forged ones are lighter, aren't they?
Posted on: 2003/8/7 5:39
Re: A12 Internals
Crankshaft Part Numbers - 12200
12200-H1000 A12 B110
12200-H1001 A12 B110 1971
12200-H5000 A12 B110 7205-
12200-H5001 A12S B210 7307-, B310 -7909
12200-H8500 A12S B310 7910-8010, A13S 8011-
The E10, N10, etc seem to use the same cranks in the same years.
There are also the Datsun Competition cranks.
12200-H8515 A12/A12A CRANKSHAFT 70mm/2.76" stroke
12200-H5720 A12 COMPETITION CRANKSHAFT 70mm/2.76" stroke
Posted on: 2003/8/7 6:04
