Datsun B210 front fender question.
From Selangor, Malaysia
Hi guys,
I have a '77 120Y (B210),last week i've bought a pair of new fender for this beauty,it stated on the fender "'74 B210" but it won't fit nicely to my car and when i installed it theres a big gap between the front fender and the hood (more than 1 inch gap which i think its not supposed to be like that)..
so my question,is there any different in gap measurement between '74 and '77 B210?or the design is a little bit different?
Thanks in advance
Posted on: 2009/4/14 7:03
dying to learn A series..help me :)
Re: Datsun B210 front fender question.
From Nyngan, nsw Australia
is it the same on both sides.....? did you put old and new side by side to check lengths
Posted on: 2009/4/14 7:30
Edited by hotrocket on 2009/4/14 8:02:23
living is good,.....
Nissan USA part numbers:
63100-H6200 ASSY-FENDER FRONT RH
63101-H6200 ASSY-FENDER FRONT LH
fits 1973-1978 B210, sedan and coupe are the same
Nissan Japan catalog:
63100-H5000
63100-H7400 1977 Feb -
63100-H5800 L16 engine models
63100-H7900 1977 Feb - L16 engine models
Posted on: 2009/4/14 7:49
From GOLD COAST AUZ
Right hand has a wide gap at top ,you will need to cut a small pice from the boltting flange between tower to A piller. take a real close look at the old guard first. Left hand will not fit at the bottom rear two bolts, thay dont line up. I cut the tab of the old guard and rewelded it on. If you had a new bonnet aswell it is smaller allround than STD. Just slow down and take a good look at old parts then the new. Know anyone that can leadfill. That what I did all around the bonnet.
Posted on: 2009/4/14 20:22
rather be a old fart than a young d##khead
thanks guys..fyi i bought the made in taiwan new fender..and my old guard have a critical rust and totally cant be saved :(
hotrocket : there's a lil' different between the length :(
dd : thanks bro for the catalog number
holeshot : u got it rite,i'm facing the same problem as u decribe ..thanks for the tips,i'll take a good look at it..and try to do what u've told..thanks again :-d
Posted on: 2009/4/15 5:45
