front end shakes "coupe"
From W.A.
my coupe has develped a really bad shake at around 80kph. If I accelerate through it nothing but as I brake the front left starts to shudder really bad. I don't thinks its the brakes as I have loaded them up and driven in 2nd and not a hint of vibration. I have jacked up the front and all the suspension components feel tight (I shook the s$%#t out of it). I then noticed oil all over the spring and stut, if the shocky is out of oil could this couse such a bad shake/shudder.
Posted on: 2009/4/15 2:17
Re: front end shakes "coupe"
If it only happens when braking, the rotor is probably slightly warped.
Posted on: 2009/4/15 2:48
From Freo
sounds like a lump in a tyre, and killed the strut...
Posted on: 2009/4/15 3:18
A15 PSI Project Motor
'72 CB750k,
the oil could be brake fluid maybe? i had a seal go on a front caliper ages ago and lost all the brake fluid, different car, differnet problems.
Posted on: 2009/4/15 3:21
From Sydney
check your front tyres and get the front wheels balanced
Posted on: 2009/4/15 5:00
If it was the tyres, would it not shake even when not braking?
Posted on: 2009/4/15 5:09
i also had similar symptoms from a worn bush and accentuated with a worn wheel bearing but was under accelartion and coasting. replaced both and gone.
Posted on: 2009/4/15 5:35
From W.A.
After further inspection I think it may be the wheel bearings are loose (slight klunk klunk when shake wheel at 12 and 6) I will let you know.
Posted on: 2009/4/15 5:47
