L16 and L18
guys did u have this 2 preasure plate @ clutch cover size will it be same or not
L16-PA10
L18-BLUEBIRD 910
plan to mods to A15
Posted on: 2009/4/22 12:49
Re: L16 and L18
From Adelaide, Australia
Both should be 200mm... there are couple different height pressure plates though, be wary of that.
Also for your information there are larger available, L18 commercial clutches (720 ute etc) are 225mm.
Posted on: 2009/4/22 12:59
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: L16 and L18
oo so the both size are the same ??
Posted on: 2009/4/22 13:02
Re: L16 and L18
Yes, L18 and L16 typically use the same clutch disk. Pickups and cars are different.
Posted on: 2009/4/23 6:22
Re: L16 and L18
10q ddgonzal...
Posted on: 2009/4/23 6:39
