« 1 (2)
Re: Question on engine mounts A15 engine swap
From SE Melbourne
Thanks dd for summing it up succinctly
Posted on: 2009/4/30 7:12
Mildman, Datsunless
From Perth WA Australia
I may not have explained this properly. The coupe is 1971 so has old type cross member. The engine mounts have been modified to suit later model A 12. Do I need to drop the engine A15 to get it under the bonnet.As the wiki article says the A 15 is higher.
Thanks
Posted on: 2009/4/30 12:48
From Adelaide, Australia
No you dont, it will fit fine. Just unbolt the mounts from your A12 and put them on the A15. Exhaust should be fine too.
If that doesnt work put a L16 in it.
Posted on: 2009/4/30 13:10
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Thanks for answering the question
Posted on: 2009/4/30 13:22
« 1 (2)
