« 1 (2)
Re: Installing aftermarket relays for headlights
Yes earth = ground, and you can leave the fuses in fron the old headlight fuse,just remember though if you headlight fuse blows for some reason you have 2 fuses to check.
LeDevil wrote:
Do you mean ground them when you say earth? Also for the switch I use my current stock switch I just use the high/low beam out puts right? If so do I leave the stock fuse in the block?
EDIT:
Sorry for all the questions but I just don't wanna screw anything up the whole object is to restore the Datto not burn it to the ground lol
Posted on: 2009/5/14 8:56
From Vancouver, Wa
Datsun1000: Yea I saw that earlier but I am confused about the switch part. Do I use my stock light switch or do I have to wire another one inside to like a toggle switch or something? For some reason this makes no sense to me and I'm not a wiring dummy I know how to do it lol but I've no never really played with relays before
Posted on: 2009/5/14 9:09
From Vancouver, Wa
Ok I think I have it, but one last question how does the relay keep the current away if there is still power going threw the stock switch and fuse??
Is the switch more or less just now a lower circut that just provides the small amount of juice the relay needs to trip to allow the "new Full" juice from the relay to go to the lamps?
Posted on: 2009/5/14 9:18
you use the stock light switch.
basically, the wires that run to your headlights, that actually run the headlights, will become trigger wires for the relays, so all the changes happen under the bonnet, id post a pic of mine to show where i put the relays in relation to the headlights but i dont know how.
Posted on: 2009/5/14 9:24
Yes exactly
Posted on: 2009/5/14 9:26
From Vancouver, Wa
Cool thanks for all the help guys I will be tackling this tomorrow after work and I will post if I have success or failure lol
Posted on: 2009/5/14 9:29
Posted on: 2009/5/14 9:38
If you have more money than time, an Relay wiring kit is really easy:
Take the new harness:
1. Connect HOT wire
2. Ground/earth the relays
3. Plug into existing headlight connector
4. Plug harness into headlights
Your'e Done! Only $129 USD
Painless Wiring Headlight Harness with relays.
Posted on: 2009/5/16 7:44
« 1 (2)
