« 1 (2)
Re: ca18det what do i need to keep and what can i throw out
From Brisbane
i used an alloy plate to cover the holes
Posted on: 2009/5/16 7:32
AWD the way to go
From hervey bay queensland
did you just tig weld them on?
Posted on: 2009/5/17 7:46
classic not plastic
From north brissy
just cut a plate the shape it needs to be and use the three bolts to hold it on
Posted on: 2009/5/17 10:42
1984 gb122(long bed) ca18det powa!
phat dat have you got any pics mate?
Posted on: 2009/5/17 10:52
classic not plastic
ok ive taken the air valve thing off the plenum and made a bit of plate to go over it
all my braided line and speedflow fittings have arrived so im replacing some lines now thanks to mildman i know now what most of them are now
now on the block before the oil filter and cooler there is a pipe that looks like it might go to the rocker cover ( cant be sure rockers are away getting polished ) so it must be a breather or something should i replace this hose with braided line or is it not needed at all?
also do you guys think the oil cooler is needed, i live in qld so it can get hot here...
cheers maso
Posted on: 2009/5/22 0:20
classic not plastic
« 1 (2)
