Browsing this Thread:
1 Anonymous Users
dip stick issues.... im still scratching my head! |
From bundy, QLD
hey guys, i have a problem.. i have a turboed a12, and the engine originally came out of a 120y before the turbo build started, whats happening is a got a sump of an a12 1200 engine, and got the return line tapped in to the sump (on the passanger side) put it on, oil filter, oil, went to check the dip stick for fluid levels and now the dipstick wont go back in? WTF!!! the 120y a12 and the 1200 a12 are identical in the sump area, so duz anyone know whats happening???? cheers....
Posted on: 2009/5/27 3:10
"71, 1200 Sedan a.k.a- old_spool- (project) 73, 1200 Sedan 71, 1200 sedan (parts car) 89, swift gti (gone now) 90, swift gti
Re: dip stick issues.... im still scratching my head! |
Registered Users Contentmaster Usermaster
Since it is a 120Y engine, use the matching 120Y dipstick.
Does the dipstick location go down the outside of the block to a bulge in the pan (which the 1200 pan does not have)?
Posted on: 2009/5/27 3:57
From bundy, QLD
i have tried the 120y dip stick and it dosent fit. it gets about 3 quarters of the way down the dip stick shaft and stops.
Posted on: 2009/5/27 7:40
Yes. Does the dipstick location go down the outside of the block to a bulge in the pan (which the 1200 pan does not have)?
The newer engines, starting with 1974 models, moved the dipstick to a totally different location! You might be able to tell by looking if that is the problem.I don't know but what you'll have to fit a B310 pan.
Posted on: 2009/5/27 8:13
Shorten the dipstick?!?
Posted on: 2009/5/27 11:41
