Part number needed.
I have searched the wiki but I can't come up with the number that I need. The part number I need is for a lay shaft (counter shaft) from a B210 option 5 speed The ratio's are as follows
B210 JDM Coupes came with:
1st 3.757
2nd 2.374
3rd 1.659
4th 1.291
5th 1.000
Rev 4.040
If someone can let me know the part numbers that would be great.
Posted on: 2009/6/3 11:04
Re: Part number needed.
From Perth WA AUS
I'm lucky if my shaft gets laid! as for a part number: if I lost it I'd be screwed.
Sorry dude can't help with that one.
Posted on: 2009/6/3 13:37
Datsun 1200 2Dr sedan.
What year is it? Early B210 with A12 used 56-series 5-speed, while B210 with A14 used 63-series 5.
Posted on: 2009/6/3 17:29
It is a 56 series 1:1 top 5 speed with the above ratios. The wiki says it is the JDM 120Y coupe?? The tooth count is
Input (5th) (29. 1:1)
4th 26. (1.291:1)
3rd 23. (1.659:1)
2nd 18. (2.374:1)
1st 13. (3.757:1) (gear is splined and not part of cluster.)
Posted on: 2009/6/3 22:06
That sounds like the standard wide ratio gearset (F5W56A)
* 32213-H7200 GEAR-counter [B110 GX-5]
* 32213-H7201 GEAR-counter [A12 B210 GX 5-speed (56-series)]
Gearsets
Posted on: 2009/6/4 3:34
