a15 piston/rods package
From sydney.nsw
A15 77.5/78mm new "FLAT TOP" cast pistons/rings balanced, A15 Conrods,are bead blasted/close&honed/little ends are bushed{floating pins}/pin buttons/balanced. & new rods bolts. Have used this package in race engine to 8000rpm so far so good. NOTE; may need to valve relief pistons depending on cam lift. Exchange rods will apply.
open for interests
jpg  GetAttachment.aspx.jpg (23.71 KB)
9764_4a3a0c74944e8.jpg 437X480 px
Posted on: 2009/6/18 10:45
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: a15 piston/rods package
From Perth
Can I get just the pistons and rings alone ?
Whats the comp ratio approx (I know this depends on chambers etc)
Posted on: 2009/6/18 10:52
From sydney.nsw
pm sent
Posted on: 2009/6/18 10:58
From Freo
looks like the rods are bushed and re sized to suit the new pins.. quality work there...
Posted on: 2009/6/18 12:53
A15 PSI Project Motor
'72 CB750k,
