NEW LINKS FOR KA24e Powered DATSUN 1200 COUPE
Not too shy to talk
From Livermore. California
U all may have seen my car at shasta and other pics that have been submitted. Here are 3 drag race runs i have on my computer before car was lowered and flared. I also just built the bottom half to 10.5:1 with ovrsized pistons, knife edgded crank everything balanced, ported head and a CAM. the videos u will see are of a stock ka24 with 45 webers, 280zx traney, and 4:38 spooled rear end.
http://www.ghettoride.com/rich/pics/1200vshatch.mpg
http://www.ghettoride.com/rich/pics/datsun1200vsWS6.mpg
http://www.ghettoride.com/rich/pics/1200vstruck.mpg
more videos to come especially since it shoud be running mid 12's now NISSAN POWER BABY
Posted on: 2003/8/27 21:39
Re: NEW LINKS FOR KA24e Powered DATSUN 1200 COUPE
Pretty cool ... neck and neck with a 5.7 liter V8 Camaro (?). I especially like the last one, how the truck has a big head start, then your Datsun zooms up to catch it.
Posted on: 2003/8/28 5:12
Not too shy to talk
Yup .. its so much fast now .. cant wait to get some new footage of it. the whole botom half i built up! Bored 40 over to increase from 89mm bore to 90mm with oversized stock pistons, new rings. I also raised compression a bit by decking the head. I also put valve release in the pistons for the big cam im running. knifedge crank, lightend flywheel, underdrive pullies, ported and poslished my head and portmatched manifold and also a must SOLID LIFTERS "Have had since begining because i was dropping valves when hydrolic lifters failed at high rpm." soon will try my 50mm in place of my 45mm! u will all soon see the wrath! ALSO im currently in proccess of building a 80 over motor with 91 mm bore / pistons. nissan dont make these so im going with a different piston i found that will work .. going to have to mod the head gasket also. Had a stroker crank made for it .. so it will go from 2.4 stock to 2.7 stroked! :)
Posted on: 2003/8/30 9:33
From Little Rock, AR
Geez, sounds like you are having a field day with those KA24's! I guess you're glad you held onto that little 1200 of yours, I remember I was so close to coming and buying it from you before you changed your mind! That's okay though, it would've had to go under a car cover for 2 years until I got back from Japan, then I was planning on hooking it up nicely. Seems you're having a blast with it now, so it's all good. I am gonna start gearing up for a SR20DET swap soon, so look out!
-Andy
Posted on: 2003/8/30 9:56
Not too shy to talk
yes i have a sr20det front clip on the way. Im joining the airforce so im having a few friends hold on to my cars for me. hopefully when i get back i will bring a r32 with me or somthing. :) anyways yeah i love the ka power its really responsive. the sr20det built up with some bigger turbos would be really funny in a 1200.. i would wrather see NISSAN in 1200 instead of the dumb rotary powered ones. We dont need mazda power to get into 7s! GOOD LUCK WITH SWAP
Posted on: 2003/8/30 16:48
