« 1 ... 3 4 5 (6) 7 8 9 ... 22 »
Re: my 1200 ute full resto, im 15 : ) [4th july pic's update colour on ]
From SA
i cant wait either!!
unm yer the spray guns are all good, but the are high quality ones, not sure what a cheap guns behave like?
the gravity feed ones are really nice tho
cheers
Posted on: 2009/6/7 9:36
Edited by Gylezy on 2009/7/4 11:31:09
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
Re: my 1200 ute full resto, im 15 : ) [17th of june pic's update]
From SA
ok so on the weekend i have installed a VZ holden tailgate mechanism, it worked really well after engineering. i have mounted the Honda CRX seats and the car is nearly finished body work wise. mechanical work will start very soon, i have an ovalport high-comp head, twin 40mm sidedraught webbers, redline manifold, 4 into 1 extractors, L16 vaulves. i am chasing up some double vaulve springs please let me know if you have some? the bottom-end will receive: rebore, new pistons, rings, bearings, balance, lumpy cam, lightened flywheel, topped off with a nice 2 1/2 inch high flow system
[/img]
i was a little side tracked on the weekend as i had a small engineering job for Sean (white sedan).
i had to increase the volume of oil holding capacity, i sectioned the endges and place wings into the sides, it was a great finaly product.
It is going on his L16 1200 sean race car, so it required the depth of the sump to be reduced as it was clashing with the X-member, for my efforts i received an origional datsun 1200 radio and a set of L16 vaulves, here are some pics.
Posted on: 2009/6/17 11:56
Go Hard Or Go Home
From SA
finally i have achieved a significant stage, there is colour on the car!! after several hours spent working on it. i have powdercoated the diff black and sprayed the rims in a white two pack, trim is nearly ready to pick up from jims trim, so is the motor from Advance engines.
it is slowly coming along :DOpen in new window
cheers Dan
Posted on: 2009/7/4 11:28
Go Hard Or Go Home
Re: my 1200 ute full resto, im 15 : ) [4th juuly pic's update colour on]
From 6065
Awesome work dude! love the matchin tailgate! gravity fed guns are the bomb for painting,no pot on the bottom to bump into the job. i use a cheap $60 suction fed gun at home til i set up my big compressor,then bring home my good gravitys from work. if you're ever holidayin in Perth,i've got a few rusty chevs that need doin..... keep up the good work!
jpg  wetChev.jpg (199.19 KB)
7792_4a4f3869f010b.jpg 559X419 px
Posted on: 2009/7/4 12:09
From SA
thanx very much mate,
yer i thought i would tie the whole theme in together, ohh i agree a high quality gravity fed gun is the way to go for sure!
ahhha ill keep that offer in mind, there is some serious potential right there, that could be a very nice ride ay, all she needs is a bit of TLC :D
how many do you have bud?
cheers Dan
Posted on: 2009/7/4 12:14
Go Hard Or Go Home
From SA
Today i picked up the, next batch of powder-coating, re trimmed seats, new nolothane suspension bushes and King Springs.
the trim was done by Jims Trims in salisbury, i am very happy with the outcome! he did the seats, kick pannels, headliner, door cards and sunvisors. the trim is a combo of black plush, red piping and a vinal carbon fiber.
cheers Dan
Posted on: 2009/7/7 9:39
Go Hard Or Go Home
Re: my 1200 ute full resto, im 15 : ) [7th july pic's updated]
From Adelaide, Australia
You guys will not believe the amount of work Dan has put into this ute, its an coming along really nicely mate.
Definitely like that trimming job too.
Posted on: 2009/7/7 10:52
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From South East Brisbane
Awesome effort mate. I'm 15 and doing my ute, would love to be doing as much as what your doing to yours to mine, but lack of shed space (none) sorta stops that from happening. Keep up the good work.
Posted on: 2009/7/7 12:13
From 6065
I only have the 48 and 2 68 Impalas(1 pillarless),others in the pipeline are my 1000 fastback chop top,an Austin A40 and a 69 Toyota Crown. not sure which way to go with the 48,leaning towards the rat rod for it these days,but i'll probly change my mind by the time i get round to it.
Posted on: 2009/7/7 14:01
From pooraka,,adelaide
still looking great man
Posted on: 2009/7/7 21:47
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
