Inside Boot
From Ballarat, Victoria, Australia
hi...just seeing wat you guys have in tha way of covering in your boot like whether you have carpeted board round the edges etc. i have nuthink not even the board that covers tha fuel tank...does any body have templates or could possibly make me some, as my boot is not really sutiable 2 put nethink in....except for a spair wheel... cheers
Posted on: 2003/8/30 3:49
-1200 4 Door Sedan, 2Pac Aruba Blue, Custom White Interior, OBX Racing Seats, SONY Head Unit, FUSION Speakers, 14" Bathurst Globes, Lowered, Powered By: A15 with Twin 40s,
Re: Inside Boot
I haven't seen any with carpet in them. Sedans are different from the others. They came with:
- a rubber mat covering the floor
- a 1/4 inch thick "wall" board hiding the fuel tank
- a 1/4 inch board covering the spare tire (under the mat)
I'll have to get pictures of mine with the original equipment -- once I get the engine out of the boot.
Posted on: 2003/8/30 17:51
Re: Inside Boot
From NorCalifornia, up by Sac
Get the engine out of the boot? Did you buy a VW or did you get a spare. I'm thinking of having the "boards" made out of aluminum or something similar. They'd hold up better. I can make a template(s) off mine, but they are a little water warped. Anyone suggest a way to straighten them out??? Put them flat & steam 'em??? Use an iron???
Posted on: 2003/8/30 22:35
Re: Inside Boot
From Tassie, Australia
In my old coupe I made a floor in the boot out of MDF. It had a rectangular peice running the width of the car behind the rear seat, I hinged a large piece of MDF off that which allowed access to the spare, worked a treat just needed carpeting.
Posted on: 2003/8/31 10:50
Re: Inside Boot
From brisbane
Hi no
Get a couple of straight, thick pieces of timber and some wood clamps. Clamp the warped timber between the straight ones for a few days and it should be apples.
Matty
Posted on: 2003/8/31 11:09
Re: Inside Boot
mmmm apples....nah not really...i have side panel boards....but they're not in there....need 2 be coverd...wats tha best ya rekon for the floor of tha boot??
Posted on: 2003/8/31 14:31
