my leaves are stuck
From cold toast
okay so i have the most rear part of my leaves off
but the front ones wont come out
the pin that bolts it all together is stuck in the bushings which are stuck in the springs
whats my best bet?
should i just burn them out, if so, are they hard to come by?
any help would be muchly apreciated
Posted on: 2009/7/20 8:44
Re: my leaves are stuck
dont burn them out, should be able to spray some anti seize od similar in there and work them out. not a quick fix but a better one. i had similar and used a g clamp on the nut end and the other on the cars haner part, worked like press, and worked like a charm, no damge either.
Posted on: 2009/7/20 8:53
From cold toast
okay sweet ill try that ;)
Posted on: 2009/7/20 9:03
From Melbourne, Australia
yeah g clamp is the go, replacement bushes are easy to come by, had some issues with buying bushes and their quality, last lot i got were "super pro", they have been the best fitting and best quality looking by far
Posted on: 2009/7/20 9:32
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From cold toast
i got it out with the g clamp on one side
the other side is slowly coming, dinners ready, so i left the clamp on with a heap of pressure and a heap of wd40 so it should be abit more loose by the time i can get back into it
Posted on: 2009/7/20 9:35
From cold toast
thanks for your help guys got both springs out and should be putting them back in on the weekend i hope
Posted on: 2009/7/20 11:35
see dont have to hack and burn stuff out to get i out. time, it all takes time. I learnt the hard way too, spend some time save some $$$$
Posted on: 2009/7/20 11:55
