e15et conversion
Not too shy to talk
From nambour qld
ok guys, am feeling more and more like putting an e15et into my b310 rally car(that will not be doing any rallys..)it should be a fairly straight forward conversion, as i think i have all the right bits already...has anybody done this before?(am gonna talk to matto1kute..)should be at least as fast as a stock sr20, and free! just wondering how you fuel inject a sunny tank...hopefully the pump will fit on the stock datto sender... cheers shane.
Posted on: 2009/7/24 12:41
Re: e15et conversion
From newcastle, NSW
matty is the man to talk to about it! you can achieve some good numbers with an E15T, go have a look at the N12 forums for more info on the engine.
Posted on: 2009/7/24 13:46
Not too shy to talk
From nambour qld
cheers! i am already an e15et nutter! had my exa long before the datto....fwd..what was i thinking?
Posted on: 2009/7/24 13:56
Not too shy to talk
From england
isn't there a problem getting the starter motor to work/fit?
Posted on: 2009/7/26 9:22
From Adelaide, Australia
nope. u can take the oil cooler of and use a A series ring gear. then u need to cut a hole in the engine backing plate
Posted on: 2009/7/26 9:25
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
From sydney
how did u do the engine mounts? and also i was told that that the E15 bell housing is simalar to the A-series, is this true? having said that i asume the clutch would be the same?
Have you got any pics?
Posted on: 2009/7/26 10:16
no good pics but very soon i have to swap my conversion to another ute so ill take some then. mounts really sucked. one side is easy to make ur own engine bracket but the other side i made a mount that is suported by the back bottom bolt of the alternator.
Posted on: 2009/7/26 10:28
From newcastle, NSW
Wiki has some info, might make things a bit clearer. It definatley worth looking into! E15's can get somme good numbers with a bit of work.
Did you ever get it engineered Matt?
Posted on: 2009/7/26 10:56
i hate that pic. thats when i was fitting it up. the turbo is still facing backwards lol.
Posted on: 2009/7/26 12:45
From newcastle, NSW
did u make up a custom turbo manifold?
Posted on: 2009/7/26 12:51
