« 1 2 3 (4)
Re: Absolute best front suspension and brake set-up
From Christchurch, New Zealand
I picked up some 910 bluebird front struts, so the next step is to grab some 120Y bottom arms?
I noted that the bluebird bottom arms are inclined at the ball joint end, this appears to be to make up for the stub axle to strut angle, can anyone tell me what effect this has on the 1200 camber?
Does the added length of the 120Y arm offset the camber problem?
The bolt spacing at the base of the strut is considerably wider than that of the 1200 strut, do the 120Y bottom ball adaptors bolt on or do I need bluebird ones?
Again thanks for all your help!
Posted on: 2003/9/13 7:20
« 1 2 3 (4)
