550 hp Blue 1971 Coupe Killeen, Texas USA
http://cgi.ebay.com/ebaymotors/ws/eBa ... iewItem&item=130324380349
My lost your gain!!! Up for auction is my 1971 Datsun. This is a serious car made for dragging purposes. What you get? Turbo 2 13B rotary engine semi periferal over 550 horse powers to the tires. Super seals, barry grant Mechanical Fuel pump, 6 1800cc injectors, accel throtle body, turbo 60-1 tial style blow off, 50mm waste gate, alcohol fuel tank in front, aluminum radiator, stage 3 clutch plate with 6 pucks clutch, engine has upgrade oil lines, turbo 2 transmission with internal modifications, anti bruto, 9 inch rear diff with 5/30 gears, dis 2 msds, microtech ECU tune by ErickTurbo, manual boost controller, linelock, micky thompson tires 26 x8x15. strange 31 splines axles, 8 point roll cage, battery located in the trunk, many more extras. This car is for racing purporses and is capable or running in low 10 or high 9 with the turbo 2 tranny. The car is pushing about 26 pounds of boost. The car has not been cut in any way the body still original with spring leafs in the back and bars. The engine is heavily modified and is been refreshened with new bearings. the car is ready to be take to the track. This is for serious racers..
Posted on: 2009/8/13 7:19
Re: 550 hp Blue 1971 Coupe Killeen, Texas USA
Posted on: 2009/8/13 20:22
High bid: US $5,000.00
Reserve not met, did not sell.
Posted on: 2009/9/20 21:32
