15 x 7 +15 offset
Quite a regular
From New Jersy USA
I know they stick out a little but how much and would 195/45-15's go just fine? just for looks its for my stock car
Posted on: 2009/8/16 18:45
Re: 15 x 7 +15 offset
I have 14x7 on my 1200. With zero offset. Your +15 will tuck inside further than my zero offset. Hopefully the won't hit the spring perch on the inside.
Here's mine. It is a tight fit:
The key to all this is the tire size (not the wheel size). Mine have 175/60R14 tires, so obviously they are stretched over the 7 inch wide rim.
195s are about the limit of what fits under the stock front fenders. You may need to roll the fender. But since they are extra low profile (small diameter) it may just work fine.
Posted on: 2009/8/16 21:00
Quite a regular
From New Jersy USA
you think it might hit inside?
Posted on: 2009/8/17 4:49
From northern 'burbs adelaide
shouldnt do im running +19 and got a few mm to spare
Posted on: 2009/8/17 4:54
Quite a regular
From New Jersy USA
Brand: Sportmax XXR wheel 513
Exclusive for MotorsportsR
Finish: GOLD with Machine Lip
Size: 2 Front Rims 15x7 with 3.0" Lip Offset +15
Size: 2 Rear Rims 15X8 with 3.5" Lip Offset +0
Bolt Pattern: 4X100 and 4X114.3 (4.5")
XXR Center Caps Included
Weight: 16.5 lbs each
Require Tuner Lug Nuts (Not Included)
195/45/15 NEXEN N3000
would these fit guys? I'm scared to send for them and I have problems
Posted on: 2009/8/18 23:21
From sydney
i run this exactly with my b45's i have 15 by 7's or 7.5's on the front but not 100% sure. i got my guards rolled and doesn't scrub but when sterring is at full lock it rubs on the inside. i run 200b struts tho and they fit without spacers.
Posted on: 2009/8/19 0:57
datto 1200 ute a12..low n slow (SOLD)
datto 1200 ute, a15 (SOLD)
fj20 1600 (SOLD)
CURRENT: 1200 Coop SR20de project Sleepin
Quite a regular
From New Jersy USA
Posted on: 2009/8/19 12:47
