pistons
Hi Guys,
Its rebuild time for the SSS and I am having sleepless nights overs pistons.
I want to open the block ( A14 ) out to 78mm ( have already had it sonic tested ) and was very keen on some Kameari cast pistons but, no longer available and at present the thinking is that I don't want to go forged as realistically this is only going to be a 8000 max. rpm engine and I would rather concentrate on reducing internal weight hence I believe that a good quality cast piston will do the job.
I have been told that I need to be careful with what I fit as a potentially heavier piston may end up in a broken conrod!!, although I have yet to see a Datsun rod break myself.
Can anybody recommend a good cast piston that is still available that will work in this application.
Cheers
Dave
Posted on: 2009/8/19 6:02
Re: pistons
This would be a good time to move up to A15, it'll rev to 8500 with stock rods.
B-Pro part #P-E-001-3, A15 78 mm pistons
http://risebike.com/pro/all%20parts%20engine.html
Posted on: 2009/8/19 6:28
Re: pistons
From Freo
It would be nice if there was Stock too.. :(
Posted on: 2009/8/19 6:52
A15 PSI Project Motor
'72 CB750k,
Re: pistons
From sydney.nsw
give me a call maybe i can help. 0412 864 741 (sydney)where r u located.
Posted on: 2009/8/19 7:00
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: pistons
Ernie,
Hi - your memory is letting you down, its Dave over in ChCh, NZ.
Any suggestions greatfully accepted!
Posted on: 2009/8/19 7:24
Re: pistons
Mike,
Is there stock of the cast A15 pistons?
Dave
Posted on: 2009/8/19 7:28
