all stock datsun 1200 "LOWERING"
Quite a regular
From New Jersy USA
Trying to lower my stock 1200 just a inch or so..nothing crazy whats the best way ? thanks
Posted on: 2009/8/20 0:22
Re: all stock datsun 1200 "LOWERING"
new springs up front, lowered ones available after market and either lowering blocks in rear or reset springs if you want to do it right.
Or flip a leaf in the rear. Look at the wiki
Posted on: 2009/8/20 1:21
Cut 1/2 coil in front, 1" lowering blocks in rear.
Posted on: 2009/8/20 2:04
Quite a regular
From New Jersy USA
thanks guys.. where do I get 1" lowering blocks?
Posted on: 2009/8/20 2:07
oh yeah forgot you can cut coils there, cant legally do here in aus
Posted on: 2009/8/20 2:08
Quite a regular
From New Jersy USA
did a search and found the blocks.. should I use 2" lowering blocks on the back since it sits higher on the back now? or just stick to one? thanks
Posted on: 2009/8/20 2:13
From ACT Aus
what model 1200 is it? something like a ute needs to be lowered much more than an inch in the rear to even out with the front. why only an inch? it'll be barely noticeable and you guys don't have laws stating it has to be 100mm off the ground etc. do ya?
Posted on: 2009/8/20 2:31
unfamilia wrote:
You have bump stops? Your soft
Just the law of good taste
Speaking of tast, I prefer the front lower than the rear but then I'm a 60s guy. Younger folks seem to like it even all 'round.
An inch will be good, allow some supension travel yet look better.
2" will look more lowered but you will have very little suspension travel (rough, bouncy ride).
Posted on: 2009/8/20 2:43
From cold toast
whats wrong with a rough bouncy ride, its an excellent trade off :)
Posted on: 2009/8/20 8:11
From ACT Aus
nah cars look way better when they're super low, so much more tasteful. you just gotta do it properly with shortened struts, stiffer shocks etc.
Posted on: 2009/8/20 8:26
