Browsing this Thread:   3 Anonymous Users
« 1 (2) 3 »
Re: o-ringing block
From Wellington New Zealand
The company I work for source them from England. We carry a good supply of spares here for various pumps etc....what size are you after.
Posted on: 2003/9/19 3:25
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
Re: o-ringing block
To fm1200
Your words are good advice
Do the homework first, do it twice if need be & get it right the first time to avoid regrets.
Thanks for the support.
Chris
Posted on: 2003/9/19 10:47
Love your Datsun.
Treat it well.
Re: o-ringing block
From Melbourne, Australia
yeah i agree fm, but this is not a SERIOUS engine, its just a bit of mucking around really, the turbos are cheap but too small so its easy enough to just use 2 of em
it may turnout to be serious but in the end im just foolin round till i have enough cash flow for the CA18DET conversion
so yeah, im at uni at the moment and just trying to do it on the cheap, therefore hoping not to rebuild, the motor i have is only 20,000 miles old anyway i was just hoping that o-ringing would be any easy way to insure against blown head gskets, apparently it is not in my case
Posted on: 2003/9/19 12:38
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: o-ringing block
From Millgrove Vic OZ
I want them to suit 86 mm bores and 89mm bores. I will go to the wills site and give you some part numbers if possible.
What sort of pumps do you service/sell wilson-snyder, geho or similar?????
Posted on: 2003/9/19 13:35
Cheers Feral
Re: o-ringing block
Yep all of those and more , I work as a maintenance engineer for Colgate Palmolive and we have a good variety of pumps here.
Posted on: 2003/9/19 20:04
1200 ute
Sunny 310 SGX.
Re: o-ringing block
Funny the similarities between pumps and auto engines. The main difference is that the reciprocating high pressure pumps are built much stronger than auto engines.
I bet the use of O rings and gas rings in engines came about from some pump repairer/engineer. The cylinder pressuresand sealing problems in auto engines are small compared to high pressure pumps.
Thats why this forum is so good (the diversity of talents that contribute).
Posted on: 2003/9/20 0:37
Cheers Feral
Re: o-ringing block
From Kyabram vic, aust,
Right,well then this engine should`ve been built with some serious BOOST in mind.
This is not intended to insult anyone,but don`t you think it should`ve been done
right the first time ?.
Yes I couldnt agree more, but this set up was built on a budget the engine is compleatly standard, even down to the staandard carby and points dizzy, yet will still blow away a standard VL turbo.
It HAS proved to be reliable, it has been to the drag strip several times and compleated 10, 15 second passes in one day with out a single engine problem.....from a internally standard engine....what more do you want???
and as RC said I played with this combination b4 going to a ca18 just for a bit of cheep fun
Posted on: 2003/9/20 2:06
Re: o-ringing block
And if it goes bang, well theres another hundred dollars and a bit of time down the drain. Cheap compared to an SR or CA blowup
I have been getting inspired by the low cost turbo formula. I wonder how much you can get out of a stocker engine with a little puffing
Posted on: 2003/9/20 13:26
Cheers Feral
Re: o-ringing block
HEAPS, i got it up and running again tonight and it tonks!!
but i need to do head gasket, she leaves a good trail of smoke and bubbles through the radiator a fair bit
it was a lot of mucking around with 4 of us working on it but finally got it good with a bit of hole elongation and other dodgey stuff
it seems to want to make more and more boost (gets to about 10psi) and at about 5500 revs it just cuts out like the fuel is not getting through anymore so im going to have to figure out how to turn the turbos down and see if that helps, fuel pressure is 14psi, and supposedly my bov is 7psi but i make upto 10psi, i dont understand how that works
Posted on: 2003/9/20 17:51
1200 Coupe Rallycar
Re: o-ringing block
Are you at the flow limit for the needle and seat. Mixture check needed to check for lean out. Also could the fuel line need a size upgrade to allow more fuel flow.
Sounds like fun! even if a bit dodgy
Posted on: 2003/9/20 23:54
Cheers Feral
« 1 (2) 3 »
