my ute needs brakes
Quite a regular
From sunny QLd
hay guys im after some info on a set up for the front of my ute as it has a ca18det i want 2 be able 2 stop the thing...
could some one please give me some info on a set up that will stop my ute..
eg. stanza struts r31 dba rotors cross drilled what callipers..? and brake booster is 240k up 2 the job?
cheers
Posted on: 2003/9/19 7:54
Re: my ute needs brakes
Not too shy to talk
From coffs harbour
ok well i have that same problem but heres what you can do 180sx hubs hilux 4pot calipers and there a few others but depends im fitting 180sx (sr20) hubs and calipers as thats what i got and it should work well maybe not the calipers but it sure better than stanza you got a brake booster??180b sss will be fine Quote:
cheers
Posted on: 2003/9/20 8:36
From Little Rock, AR
B310 front control arms, tension rods, and lower ball joint/steering arms, and 280ZX front struts/brakes. You have to cut off the old spring perch and mount a new one, but supposedly the bottom matches up.
Posted on: 2003/9/20 9:23
From brisbane
I've just had some brakes built for me by Kev Rowley here in Brisbane that I'm very happy with. They are 120Y front struts with Silvia rotors and calipers mounted onto them with a 10mm plate. Even with my ute still having the rear drums it pulls up very quickly without any fuss. Being late model parts you can easily get aftermarket slotted rotors, kevlar brake pads etc.
Matty
Posted on: 2003/9/20 11:56
