help needed with dizzy
From sydney
hey guy
just in the process of wiring up my new computer and i need a timing point does an e15 distributor have the this feature or do i need a crank angle sensor
thanks
Posted on: 2009/9/13 3:58
Edited by mitch_dato on 2009/9/13 21:46:04
Re: distributor
From Southern Highlands, NSW, Australia
What sort of computer is it? Some fuel only computers will run on a tacho signal, but most of the newer ones require a crank angle sensor.
Posted on: 2009/9/13 8:23
'72 1200 sedan hillclimb/supersprint car
Re: distributor
From sydney
yea its a ems and on the wiring diagram is says dizzy or sensor
Posted on: 2009/9/13 8:52
Re: help needed with dizzy
From sydney
does anyone no
Posted on: 2009/9/18 7:04
From Bris Ozzztraileeaarr
I know it sounds obvious but have you asked EMS?? Good luck mate
Posted on: 2009/9/19 22:58
No, an E15 distributor does not have a "timing point". Like every 4-cylinder distributor it has a current pulse every 180 degrees inherent in the wire. Unlike some newer (late 1980s) electronic distributors, it has no specific signal output.
With most EFI controllers you do not need a timing point -- it is only used with sequential EFI or individual coils. Put the controller into constant flow mode and 'wasted spark' mode and you should be OK.
Posted on: 2009/9/19 23:25
