« 1 2 (3) 4 5 6 »
Re: Rover V8
From Millgrove Vic OZ
The only advantage the Rover engine has is they are light and in stock form make a good amount of torque.
The Matich SR5 and the Traco olds were my dream cars when I was a young tacker, and they were unbeatable on the day they held together. Franch Matich got some pretty good stuff together for his time.
I think the small block Chevs are a good as well, but where can you get an alloy block for them at a reasonable price??? The blocks cost an arm and leg. I reckon you might as well get a Nissan VH41/45 and do it up
What money does he want for the rover and box? This is not Steve P is it?
Posted on: 2003/9/24 8:48
Cheers Feral
Re: Rover V8
From Melbourne, Australia
bah
turbo a small motor (4cyl)
get the same speed, much less wieght, great handeling and it will actually stop!!!
wake up peoples, force fed is the only way to go, V8 is redundant!
well that said there is one use for large capacity, and thats pulling heavy weights, i.e. botas/caravans but having one just to pull the weight of the motor itself is rediculous
so yeah, morale of the story, unless you just want to point and shoot, forget the v8 there is no advantage!
nuff said
Posted on: 2003/9/24 8:53
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Rover V8
pet hate:
people braging bout alloy this and that without quoting actuall weights
cause in my experience the alloy stuff is never really THAT much lighter that its the fantastic thing people make it out to be
Posted on: 2003/9/24 8:54
1200 Coupe Rallycar
Re: Rover V8
Chev Gen III 300 kW - complete engine including flywheel & clutch all accessories. 208 Kg's. Gearbox inc fork and crossmember 63 kg's.Total 271 kg's
Width is 600mm across heads, length is 850mm and height is 600 mm. Hows them apples!
A12 with manifolds and stock flywheel and clutch 97 kg's 120Y 4spd 19kg with mount & x-member, dry Total 116 kg's.
L20B with webers and manifolds 152 kg's Stanza box 35 kg's Total 187 kg's
Im starting to wonder why i didnt put a gen III 300kw in the sunny for my daily driver
VROOOOOOOOOOOM
Posted on: 2003/9/24 9:30
Cheers Feral
Re: Rover V8
because back to my first point, the barstard weights 155kg more than stock
and as you should know this is gonna seriously screw up any handeling or braking
oh, and the plastic sleeve around number one, but thats not what this discussion is about
Posted on: 2003/9/24 9:34
1200 Coupe Rallycar
Re: Rover V8
Well if I can get that mass back a further half block distance, then its probably no worse than having a big fat bugger as a passenger (or driver )
Starting to sound like a sports sedan now isnt it Ah well dream on.
I have other 4 cylinder fish to fry at the moment
LZZZZZZZZZZZZZZZZZZZZZZZZZZZZ's.
Posted on: 2003/9/24 9:49
Cheers Feral
Re: Rover V8
what is this LZ thing ya want for christmas, me no nothing about it
Posted on: 2003/9/24 9:53
1200 Coupe Rallycar
Re: Rover V8
From Wellington New Zealand
He He this thread is starting out like the rotary one...people seem to have very strong opinions on engines on this forum. I think the Rover V8 is an awesome engine, in it's Oldsmobile form I think it was the worlds first turbocharged production car engine. In the mid 60s and it had a crude form of water/alcohol injection to stop pinging. The age of an engines design doen't mean it is inferior it must be good to stay in production..I mean our beloved A series has been powering cars since 1970 and is still going strong in the Bakkies. Building HP in a Rover isn't hard and with a combination of Holden and Chev parts (they are all GM anyway) you can build a strong durable engine. BCF is correct about weights too I have built a couple of MGB V8s and the Rover only weighs more than the CI 4 potter after adding the coolant. I have got up to over 150MPH in a MGBGT with a 3.9 Rover based engine...I know this speed was accurate because the cop who pulled me up verified it !!!! I have seen Rovers dropped in Dattos and they fit well though as I get older I seem to becoming more of a purist. I have to say nothing makes a better noise than a strong V8 at full cry....pommy or other wise I admit it guys I must be a bogan with no chance of recovery.
Posted on: 2003/9/24 10:12
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
Re: Rover V8
Once Errol has sold his wife and his left nut he will have enough coin to purchase what I would consider the ultimate 1200 engine a genuine ex works LZ14 twin cam as fitted to the 76 factory coupes with mechanical injection and dry sump...thats all, nothing special really I suppose, I don't know why he is getting excited?... I mean hell there must be at least what,.. 20 of them left in the world,
Posted on: 2003/9/24 10:29
1200 ute
Sunny 310 SGX.
Re: Rover V8
hmm yeah does sound alright
thats not whal all the excellents had is it??
Posted on: 2003/9/24 10:32
1200 Coupe Rallycar
« 1 2 (3) 4 5 6 »
