« 1 (2)
Re: cooling system issues? again
thermostat is new ish, was new when installed, but the rad seems ok by using the hand test of temp across the core when hot.
Only issue with changing the clutch fan for a normal one means replacing the water pump, the stud hole spacing is different for clutch fan and normal fan on the water pumps.
might just do that as i have to drain the coolant any way, also do the thermo stat and see.
Posted on: 2009/10/24 6:33
Like this?
You can fit the A14 fan on it (negative offset fan)
just need the pully and spacer
Posted on: 2009/10/24 8:31
if i could find an a14 fan and stuff. got an a12 one but even with pully and spacer, the holes are different spacing. weird.
Posted on: 2009/10/24 9:56
« 1 (2)
