« 1 2 (3) 4 »
Re: 4agze vs Ca18det ???
Ok, you have to look at legality too...I doubt you will get a 13B turbo or an FJ20 turbo engineered.
As I understand it, the maximum you can have is 1.8 turbo (Correct me if Im wrong here). As you might as well go the biggest capacity possible, this leaves the CA or BP (or any other 1.8 turbo you can find).
Posted on: 2003/10/6 2:25
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
From Sydney
the mazda bp looks appealing. Wots the deal with a 6-cylinder motor in a 1200. I reckon if there was one that was legal in NSW (ie under 2400cc), and would fit, id do it. That would be sweet. loads of torque and wheelbarrows of fun fun fun.
Posted on: 2003/10/6 3:24
From Melbourne, Australia
i was thinking of that (1.8T) but number 3,4 and 5 fastest 4cyl cars (1/4 mile) are 2ltr turbo datsuns so i included their motors
Posted on: 2003/10/6 8:37
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Mandurah WA
matbighat wrote:
Better yet, do the Mazda twincam conversion. Looks just a cool as the Toyota, but lacks the stigma of the Toyota vs. Nissan rivalry. Seems like there's tons of side to side room (despite the firewall being notched on this ute).
That engine is the FE DOHC
And they are more powerful then the CA18DET in stock form.
The FE-ZE 10.1:1 Compression Ratio devolpes around 170hp compared to the 180 from the CA18DET
Posted on: 2003/10/6 15:55
1984 Mazda 626 stocker..
Soon to be 32/36 weber powered
From Mandurah WA
The BP is a 4cyl not a 6cyl.
Some other good engine to look into are the KL's by mazda like the KL03 KLZE KFZE :)
Go too mx6.com search for them and should turnup some good results.
Posted on: 2003/10/6 16:01
Not too shy to talk
From coffs harbour
the mr2 is oz's fastest ran 11.7@119mph on pirelli street tyres here da specs
non oil squirter block stock internals stock head k&n pod GT30 turbo manifold 3"zorst water air cooler 3ltr plenum MTX8 500hp in tank pump 550cc injectors optimax fuel malpassi reg 6line speed flow fittings remote oil filter block 204kw @ wheels 1.72bar boost
this is from zoom No:62 will the white supra on front Zilla Killa
Posted on: 2003/10/7 9:00
oz's fastest what???
fastest 4agze???
fastest 4cyl are in the 8's
Posted on: 2003/10/7 9:13
1200 Coupe Rallycar
From Mandurah WA
he ment Oz's fastest Mr2
but beat this there is a Mr2 running 11's on stock ECU injectors everything except intake and exhaust.
Posted on: 2003/10/7 16:13
*cough* bullsh_t!! *cough*
Posted on: 2003/10/8 10:36
Not too shy to talk
From Sydney australia
go 12a rotary
Posted on: 2003/10/8 11:05
Give it a hit
« 1 2 (3) 4 »
