what x-member
From cold toast
hey, just wondering how do i find out what cross member i have in my 1200 ute
and if its the compatatble one for an a15 swap
thanks
Posted on: 2009/10/29 10:32
Re: what x-member
From Armidale N.S.W
by the year model later than 74 model and ya in business
Posted on: 2009/10/29 10:34
73 1200 wagon SOLD
Re: what x-member
If the engine mounts sit at approx the same height it is early, if the drivers side mount is approx 50mm higher (staggered) then it is the late type.
Posted on: 2009/10/29 11:27
Re: what x-member
top is old a12
bottom is a12a a14 a15
jpg  23102009161-001.jpg (188.35 KB)
10308_4ae986c284762.jpg 800X600 px
Posted on: 2009/10/29 12:13
Car free
Re: what x-member
From cold toast
my passenger side one is low and drivers side is high,
how do i find out what year model my ute is?
Posted on: 2009/10/30 12:36
Re: what x-member
From Tamworth , NSW
rego papers??
plate under bonnet on passenger side??
all it takes is a look!
Posted on: 2009/10/30 19:21
Re: what x-member
Easiest way to tell: Look at the engine that's in your ute now:
* Mid-dizzy engine: it's compatible with A15 swap
* Front-dizzey engine: it's not compatible
Either way you can make up new mounts, OR swap crossmembers. All 1200 crossmbers can be used with A15, it's just that the newer kind if a straight bolt-in.
Posted on: 2009/10/30 20:37
Re: what x-member
From Armidale N.S.W
Yeah you have a late ute cross member in it old cross member has mounts of equal height as i said anything after 74 is all good.
Posted on: 2009/10/30 23:10
73 1200 wagon SOLD
Re: what x-member
From cold toast
pepper, i did have a look under the bonnet but i dunno where to look, i looked at the two plates on the firewall and they didnt say anything aboutwhat year as far as i no
and thanks for your help guys
Posted on: 2009/11/1 9:42
Re: what x-member
From Tamworth , NSW
if you have 2 pplates you will see on the one on the passenger side will say 4/74 or something like that .
Posted on: 2009/11/1 10:48
