A14 gaskets. Tech question.
Not too shy to talk
From Sacramento, CA, USA. Where the tax dollars die.
I see gasket sets that are listed for 75 to 79 A series engines. Will they work on an 81 engine? What is the difference?
Posted on: 2009/12/11 16:17
Re: A14 gaskets. Tech question.
I take it you are in USA?
The A14 came in 1975, that's why it says 1975- up.
The 1981-1982 engines have different size intake ports.
See http://datsun1200.com/modules/mediawi ... l-Oval_Shrouded-port_Head
Posted on: 2009/12/11 19:00
Not too shy to talk
Thanks ddgonzal.
So, If I am using an 81 block with an earlier H72 head, would I use a gasket set for 75-79 engines?
Dave
Posted on: 2009/12/11 19:17
Yes, use the set that matches the head. The block gaskets are all the same.
Posted on: 2009/12/12 4:46
