help with clutch problem
From Adelaide, Australia
hey guys i have a toyota 4 runner. im having problems with the clutch and slave. ive rebuilt them but i cant get them to bleed up. aparently i have to bleed the single clutch master but how do i do that?
UPDATE
ive rebuilt the master and slave and they seem to work as the slave piston travels about 1.5cm but i still have a clutch problem. is there any chance the clutch could have shat itself? its only 6-8 months old
Posted on: 2009/12/23 0:36
Edited by Matto1kUte on 2009/12/23 9:30:59
Re: help with clutch and slave problem
To bleed a master cylinder:
1. Slightly loosen the fitting for the hydraulic line at the master cylinder
2. An assistent press and hold down the pedal
3. Tighten the fitting
4. Assistant release the pedal
It makes a mess. Flush the engine compartment with water when finished.
Posted on: 2009/12/23 2:26
so i gather what u mean is to let the air out where the master conbects onto the metal line
Posted on: 2009/12/23 2:28
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
Yes, but mostly brake fluid will come out.
Posted on: 2009/12/23 3:00
Re: help with clutch problem
anyone?
Posted on: 2009/12/23 9:31
Do what dd said thats how you bleed brakes aswell
Posted on: 2009/12/23 12:32
