« 1 ... 4 5 6 (7)
Re: A-series high RPM water pump mods.
From Adelaide, Australia
I am using my 160f thermostat gutted as a restrictor.
Posted on: 2010/1/19 4:52
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Cape Town South Africa
I dont have any heating problems with my L20 setup but if it ever start getting a problem you guys have given me a bit to think about. Thanx!
Posted on: 2010/1/19 6:25
Racing started the day the 2nd car was built!
From Johannesburg-South Africa
my 140y was overheating yesterday, above the high mark of the car, not sure wats causing it, as the radiator is full off water, had my radiator recorded about 2 months ago to a 3 core, taking my water capacity up from just over 2 litres to over 4 litres, surely there is enough water, almost half gets lost, i see no leaks, I believe my thermostat has been removed also, I'm thinking its the waterpump that has the problem. Also when I filled the water up and ran the engine, bubbles appeared big ones and also small ones making a bit of a frothy look. Any ideas?
Posted on: 2010/1/20 14:20
Hi TJ, post a new Topic for your question. Unless it has something to do with high RPM water pump modifications it should be a new Topic.
Posted on: 2010/1/20 16:17
« 1 ... 4 5 6 (7)
