datsun 1200 Ute EXTREMELY WORKED A12!
From QLD toowoomba
up for sale is my very loved 84 1200 ute.. body isnt very good... fair bit of rust (repairable) but the motor is where all the $$ is. I am a mechanic, i just rebuilt it. here is a list of things done:
rehoned a12 block and decked
a14/a15 H891 oval port head - japanese double valve springs (rated to 10,000rpm), port and polished and shaved and new larger valves by CF Performance.
Twin DHLA 40 Dellortos on a redline port matched and polished manifold with redline soft mount kit. and 4 uni filters and ram tubes. dyno tuned by cf performance
recurved distributor, new points, msd blaster 2 coil, new leads, plugs, rotor, MSD ballist resistor.
very large 140 grind cam (new), new lifters
New flat top pistons, rings, bearings, reground crank and balanced crank. new gaskets and seals
Extractors, 2 inch exhaust into a muffler and a 2.5 inch chrome dump pipe (muffler king)
flywheel is stock. has a old 4 speed box
new startermotor
Racer Fuel pump (8psi) (needs relocating to under tray... it is cuttently mounted on firewall but drains back and stops pumping fuel)
has 4 new tyres on 13 inch globe wheels (175/70 R13 i think)
standard diff
standard clutch
front disc brakes and low king springs ( around 2 inch drop )
2 inch blockes in rear.near new gas shocks
new black carpet, black and silver cope dash (with tacho), recovered seats in moroon and white, no head rests, black custom kick panals with datsun emblem in them, black door cards. pioneer dvd player, kicker splits, mpx audio 6x9's in boxes behind seats and mpx audio 4 chanel amp. (amp is optional...$300 added 2 sale price)
the ute is very quick for a 1.2L (runs in the 15s currently 1/4 mile)
perfect p plate car. currently rego'd for 3 more months. does not come with rw... no time and no licence at the moment.
has been nudged in the rear. all windows good. needs new rubbers (doesnt leak but).
it is white
so if ur after an awesome engine with under 5000ks on it and a half descent body this is the car for you. its is a major street sleeper except the exhaust is loud (needs a resonator)
oil and filter changed every 2000ks since rebuild. new coolent.
fair few spares if interested to go with the car.
selling car due to no licence any more and need the money for new project.
$4500 ono... road worthy will be ur responsability but arrangements can be made for it to remain registered untill that date.
has allways been a toowoomba car with log book and lots of reciepts.
call me (locky) on 0431 942 511 for any questions. thanks
Posted on: 2009/11/27 9:30
84 Datto 1200 ute. flat top pistons lumpy cam h891 shaved head lightened flywheel
Re: datsun 1200 Ute EXTREMELY WORKED A12!
From QLD toowoomba
ute is located in highfields (just outside toowoomba QLD)
some photps are at http://www.facebook.com/home.php?ref= ... 69570&id=798854553&ref=mf
Posted on: 2009/11/27 9:46
From QLD toowoomba
Still 4 sale. need it gone! $4000
Posted on: 2010/1/30 2:49
From Freo
good luck with the sale, seems like a reasonable price,
Huge fan of the 4 spoke Sprintmaster wheels.. :)
Posted on: 2010/1/30 2:57
A15 PSI Project Motor
'72 CB750k,
What is the password to see the Facebook photos?
Or, can you just attach the photos here?
Posted on: 2010/1/30 3:56
From sydney
To bad your not in sydney...
Posted on: 2010/1/30 6:11
PROJECT:DATSUN sunny sedan CA18det
From Perth WA AUS
DD, I think if you are logged in to facebook it will show you the pics, not sure but works for me.
Posted on: 2010/1/30 8:26
Datsun 1200 2Dr sedan.
