« 1 (2) 3 4 »
Re: Another CA 1200.
From Nyngan, nsw Australia
coming along take your time dont rush it,
are you using aftermarket 1/4's, just tack them on first make sure doors line up with them, i came close to having the 1/4's fully welded on and thourght i better check it doors line up.....lucky i checked first....
i also found with one of my front guards (aftermarket) it will need replacing its out about 10mm wont line up with the door, even with abit of fiddling around......keep plotting along
Posted on: 2010/2/6 20:18
living is good,.....
From sydney
Yeah thanks hotrocket. I was thinking about that night,i did a quick mok up yesterday looks not to bad. As for the guards i to have the same problem with bolt holes not lining up, but with a bit of time ill make them fit =)
Posted on: 2010/2/6 21:53
PROJECT:DATSUN sunny sedan CA18det
yeah bolt holes there nothing its the creases and curves that are problem.....thats what you get when buying aftermaket stuff
cheers rod..
Posted on: 2010/2/6 22:02
From Melbourne ( West )
I had the same problem,
however - when I spoke with my panel beater, he advised me to buy ALL after market panels as they should line up with each other. I did this and it took him alot less time to get the gaps and everything right.
Posted on: 2010/2/6 23:48
'78 Ute CA18det Project
No matter where you go... There you are
From sydney
after looking at it today i think its best just to let it go ( sell ) don't rally have the money right now + the move to QLD, its just all at the wrong time.
If anyone has any offers...
Posted on: 2010/2/7 5:13
What happen to "Yeah this is a keeper"...you lots interest all to hard now?
Posted on: 2010/2/7 5:44
From sydney
Nah not to hard at.. all the damage to the lower tray got fixed and welded up. I was thinking im not going to have the money to finish it to the way i want it and also the move to QLD. I might just buy one up there.
I think i should at least get $1800 with all the new panels to finish it off.
Posted on: 2010/2/7 8:07
Posted on: 2010/2/7 19:29
From sydney
Thanks ... THAT'S YOU ONE =)
Posted on: 2010/2/8 9:58
just dont finish it 100% the way you want- do a quick matt paint job on it and get it on the road- drive it for a bit then do it the way you want within a couple of years when time and $$$ permit- it really looks pretty rust free and a keeper.
Posted on: 2010/2/8 10:46
« 1 (2) 3 4 »
