« 1 (2)
Re: Need Help...Timing Chain Alignment
From Selangor, Malaysia
hi guys,
my friend manage to find an answer for my problems..referring to this link in this great forum
Cam/Crank Gear Alignment
and i think this is the way i should do it..the only thing that is aligned is the white mark as shown in the picture..
Posted on: 2010/2/9 6:34
dying to learn A series..help me :)
That won't work. The white does are for aligning the chain marks.
The aligning in a straight line is the cam dowl and the crank key. Lay a straightedge along there to be sure, it is more accurate than just eye-balling it.
Like this:
jpg  100_1305x.jpg (71.78 KB)
174_4b710b05e14a6.jpg 800X593 px
Posted on: 2010/2/9 7:13
i'm so sorry but i get a lil'confused here..
so it doesnt matter where the position of the piston as long the crank key is aligned with the camshaft dowl?
thanks.
Posted on: 2010/2/9 7:49
That's right.
Remember that when the crank is in that position, it may be TDC for #1 piston, or it may be TDC for #4 piston. Remove the rocker cover and check which valves are loose. The loose ones will be at TDC on the compression stroke.
To double check, place the timing cover on loosely, and the pulley. Then you can check the timing marks.
Posted on: 2010/2/9 7:56
ok..thanks DD,i'll post up the result soon..thank u very much..
Posted on: 2010/2/9 8:11
From SE Melbourne
There are a few more pics of me putting an A14 back together (a couple more of the timing chain too) here:
http://mildman.datsunprojects.org/Blue_index.htm
Page 6 of "A14 Prep" has the timing chain photos
Might help answer a couple more Q's.
Good luck
Posted on: 2010/2/9 11:02
Mildman, Datsunless
« 1 (2)
