NEW CARBY(S) NEEDED
From newcastle, NSW
HAS ANY ONE OUT THERE IN DATO LAND GOT A CARBY OR SET OF TWIN CARBYS? I NEED A WEBBER OR SOMTHING SIMILAR, SE QLD AREA. MY WEBBER THAT I HAVE ON AT THE MOMENT IS ON ITS WAY OUT AND I NEED ONE ASAP
Posted on: 2003/11/2 5:15
Re: NEW CARBY(S) NEEDED
From BRISBANE NORTHSIDE
Hi Steveo,there is a mate of mine in Ipswich Garrys his name,he is into cortinas,might be able to supply a Webber for you.ph32817005.Also i have a single sidedraught manifold and a 40mm Delorto if that might suit you ph33513655
Hope this might help
Jim
Posted on: 2003/11/2 5:50
From newcastle, NSW
Thanks for your reply jim! You haven't by any chance got a dellorto to fit that manifold? if you have i would be very interested in obtaining it from you.The thing is, i don't know how hard it is to obtain a 40mm dellorto, i might have to scour some wreakers and see what i can come up with. i still haven't rang your mate, would he have one?? has anyone got one???
Posted on: 2003/11/6 23:41
From Melbourne, Australia
ive got 2 i picked up but dont really wanna seperate em, $250
look in alfas if ya can find em at wreckers, mine are straight out of an alfa, cant remeber what model, started with a "G"
Posted on: 2003/11/7 0:25
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From newcastle, NSW
they wouldn't be off a GTV, by any chance? alfa twin dellortos are good quality carby(well i think so!) the only thing is will they run on a A14? they should but,i bought a set of twin SU's couple of years ago and buggered if i know how the fella i bought them off got them to run. I reakon they needed re-jetting,to much time and dollars involved so that idea got shelved. So, can you tell me a bit about the dellortos?
Posted on: 2003/11/9 1:07
Hi Steveo.Yes i do have a 40mm Delorto,dont know what it came off,probably an Alfa but not sure.The manifold is for a round port head thoughs so depending on which head you have on your A14 may not fit.Hope this helps.
Jim.
Posted on: 2003/11/9 9:19
From newcastle, NSW
HOW MUCH DO YOU WANT FOR THEM?? DOES THE CARBY FIT ON THE MANIFOLD?WITH OR WITHOUT AN ADAPTER PLATE? I'M KEEN AS MUSTARD! I WAS TOLD THAT THE ALFA DELLORTOS ARE A GOOD QUALITY SO THEREFORE I'M VERY INTERESTED, LEAVE ME A MESSAGE WITH YOUR DETAILS AND I'LL GET BACK TO YOU! THANKS JIM!!!!
Posted on: 2003/11/12 6:05
