Camshaft Q.s
From New Zealand
Hey guys looking at buying this camshaft:
Intake advertised duration: 286 degrees
Exhaust advertised duration: 286 degrees
Intake duration @ .050": 230 degrees
Exhaust duration @ .050": 230 degrees
Intake cam lift: .285"
Exhaust cam lift: .285"
LCA: 108 degrees. (lobe separation)
Timing @ .050” intake opens 7 degrees BTDC closes 43 degrees ABDC
Timing @ .050” exhaust opens 43 degrees BBDC closes 7 degrees ATDC
what sort of mods will i need to support it?
Posted on: 2010/2/23 6:10
Re: Camshaft Q.s
From Christchurch. NZ
as much as you can afford.
Posted on: 2010/2/23 8:00
Re: Camshaft Q.s
From Invercargill, new zealand
is it second hand? a second hand cam shaft will wear out faster than a new one because it wont be bedding in with freshly re-faced lifters. Well thats what they tell us anyway. I have a similar grind (0.295" lift in and ex, 293 duration in and ex advertised, 233 duration in and ex at 0.050") which was done by CSL cams in palmy north. Mods i did with it was refaced lifters and uprated valve springs.
With that camshaft you should at least run twin SU carbs or a decent downdraught weber or similar. set of headers and thats about it if you are just after a warmer street engine.
What engine is it going into? a12/14/15 and with what head?
Posted on: 2010/2/23 8:03
Re: Camshaft Q.s
From New Zealand
The camshaft will be going into a A14 block with 1.00mm O.S high comp pistons, lifters are new. The head im using is off a A15 I think its a H89?
Posted on: 2010/2/23 8:55
Re: Camshaft Q.s
ok, as long as you have a reasonable carby and exhaust that will be fine. Uprate your valve springs if you want to rev. Youve done the right thing with high compression pistons as apparently a lumpier camshaft will reduce compression at low rpm from stock levels so you need to increase your compression ratio to compensate. Ive got dish top pistons but only because flat tops were around $600 for a set
Posted on: 2010/2/23 9:22
Re: Camshaft Q.s
From New Zealand
sweet. Will a cortina carb do the job? Ive got the exhaust side of things sorted.. I build exhaust systems for a living. Will i have to do anything to the intake/exhaust ports? Are the standed ports big enough for that cam?
Posted on: 2010/2/24 5:43
Re: Camshaft Q.s
stock ports are fine for street use they say. If you port out then you could possibly lose some low down torque. you could polish the exhaust ports which is meant to reduce drag but dont do it to the intakes as a rough intake port encourages good fuel and air mixing. Remove casting marks.
What are you expecting out of this engine? that will determine things like porting.
Posted on: 2010/2/24 18:53
