« 1 (2)
Re: help needed! engine coughs uncontrollably
From sydney
i investagated further today and found out that the inlet manifold was craked and broken on the inside bolt hols, when i undone the manifold to have a look the bits just fell off, is this a comman problem? the timing seems to be right, if i set the timing to 0 it doesn't seem to run very good but if i advance it past 10 degrees it run a little better bu stil wont idle that well. i think ther is somthing wrong with the engine it self, theres some strange noises from the engine somwhere, that only started today when i was working on it! just my luck!
Posted on: 2010/3/7 8:46
From Brisbane, QLD
Has it got a standard cam? because it sounds like the cam timing is wrong and it is common for people to put different cams in and not dial them in correctlty
Posted on: 2010/3/7 10:34
From sydney
apparetnly it had a turbo cam in it but i can't be sure, to be honest i'm not exactly sure. I think the problem is terminal though, it has what sounds like a high pitched squeele comung from the motor somwhere. i've tried the valve clerences and done the timing about 10 times checked everthing i could possibly think of i think it runs alot deeper than those things, there has to be somthing wrong internaly it must be? i've checked everythig else. I'm stumped!
Posted on: 2010/3/7 11:04
From newcastle, NSW
thats a bummer! thats the problem with buying second hand performance parts you don't know exactly what you're getting, that sucks!!
sounds like there is something more than meets the eye, usually it a relitivly easy to set the timing and do a basic tune up, but it could be a number of things.
Good luck with it!
Posted on: 2010/3/7 11:30
Another possibility is lean mixture as this can be a cause of the symptoms that you describe.
You have not mentioned what induction you are using & it is not clear if it still has the turbo fitted or not.
If a stock carb is now fitted then it has a window in the float bowl & you can check the float level just by looking at it.
If all else fails then ensure that the float level is correct, the needle & seat or fuel lines are not partially blocked [including the filter] & that the jets are adequate for the engines needs.
Posted on: 2010/3/8 0:57
Love your Datsun.
Treat it well.
« 1 (2)
