Re: A Series Max Revving
Back in the early 1980's I had a 1971 1200 coupe that I built for local club rally's. The engine was fully balanced, but stock pistons , rods etc. I had a rally cam (cant remember the make or grind) and ported and polished the head myself. Ran a single 45mm weber dual throat carby choked to 32mm and jetted to suit a lynx crossover manifold. At the time we rebuilt the motor my mate was working as a mechanic in a servo and had just pulled down a blown motor out of a toyota dyna truck, we found that the inner valve springs on the dyna fitted perfectly inside the stock valve springs so we gave them a try. After running the engine in it would rev to 8000rpm no worries and continued to do so for quite a few years. Not long after the rebuild I had to fit a race clutch as the original disintegrated when changing from 1st to 2nd at 8000 revs one day. Finally I totalled it by taking 3 pine trees out of the ground at around 80mph in a club rally. The old Datto was amazing the punishment it took, one day I hope to get another and rebuild.
Posted on: 2010/3/13 7:21
Subject Poster Date
     A Series Max Revving bituten 2009/12/1 4:32
       Re: A Series Max Revving ddgonzal 2009/12/1 5:44
       Re: A Series Max Revving bituten 2009/12/1 6:23
         Re: A Series Max Revving ROConnor 2009/12/1 6:32
       Re: A Series Max Revving bituten 2009/12/1 7:06
       Re: A Series Max Revving silvia-specr 2009/12/1 7:27
       Re: A Series Max Revving bituten 2009/12/1 7:41
         Re: A Series Max Revving WhiteSedan 2009/12/1 7:51
       Re: A Series Max Revving bituten 2009/12/1 8:10
       Re: A Series Max Revving silvia-specr 2009/12/1 8:30
         Re: A Series Max Revving greendog 2009/12/1 8:58
         Re: A Series Max Revving dodgeyboy 2009/12/9 10:09
       Re: A Series Max Revving bituten 2009/12/1 9:06
         Re: A Series Max Revving ddgonzal 2009/12/1 20:03
       Re: A Series Max Revving racetech 2009/12/3 8:39
       Re: A Series Max Revving superbin 2009/12/3 8:58
       Re: A Series Max Revving thedevilshands 2009/12/3 10:35
       Re: A Series Max Revving superbin 2009/12/3 10:41
       Re: A Series Max Revving thedevilshands 2009/12/4 2:09
       Re: A Series Max Revving racetech 2009/12/7 7:41
         Re: A Series Max Revving 1200rallycar 2009/12/7 7:47
           Re: A Series Max Revving Rallytwit 2009/12/8 1:30
             Re: A Series Max Revving ddgonzal 2009/12/8 9:03
       Re: A Series Max Revving bituten 2009/12/8 9:46
       Re: A Series Max Revving TJ-Flames 2009/12/8 11:59
       Re: A Series Max Revving bituten 2009/12/8 16:02
         Re: A Series Max Revving Rallytwit 2009/12/9 3:28
       Re: A Series Max Revving demontweaks 2010/3/12 9:52
         Re: A Series Max Revving Rallytwit 2010/3/13 4:59
           Re: A Series Max Revving Stevewarren 2010/3/13 7:21
       Re: A Series Max Revving m74b210 2010/3/13 17:43
