Electronic dizzy problems
From SA
gday,
i think i have a electric problem, and was just wondering if somone could shed some light?
I am running an electric dizzy, from Mal with a crane coil pack LX91 coil, non resisted
it will run no worries for about 15 minutes, then nothing it dies... i check the spark straight off the coil and there is nothing at all...
its happened twice, once last weekend and again today...
so its cost me two of mals dizzys
can anyone help out ?
any help is greatly appreciated
cheers
Dan
Posted on: 2010/3/13 10:43
Edited by Gylezy on 2010/3/13 11:57:40
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
Re: Electronic dizzy problems
From Bathurst - NSW
Still running your ballast resistor?
Posted on: 2010/3/13 10:55
From SA
no the the guy at OG speed shop told me to take it all out, should i be running it ?
cheers
Dan
Posted on: 2010/3/13 11:02
Go Hard Or Go Home
From Bathurst - NSW
No, took mine out also. Are you running 12v to the coil, and nothing else from the coil, ie tacho, etc.
Posted on: 2010/3/13 11:12
From SA
yes straight 12v to the coil... no tacho or anything at all
im stumped ???
cheers
Posted on: 2010/3/13 11:18
Go Hard Or Go Home
From Bathurst - NSW
I've had a unit fail on me twice also (aftermarket), turned out it was the dizzy itself, sounds like you're getting the same reception!
Posted on: 2010/3/13 11:22
From SA
yeah i dunno,
chris had one of those dizzys running in his 1000 for about a year, so its not that dizzy, but my ute managed to cook it...
any one else have any input?
i apperciate your help BRUTE thanx very much mate
cheers
Dan
Posted on: 2010/3/13 11:51
Go Hard Or Go Home
Ye mate.
I reckon you got it in the wrong hole aye???!
Dirty-dizzy-burner you dan. Them are good dizzies. Your engine must prefer fairy dizzys, you know, the pink ones.
Posted on: 2010/3/13 15:26
The crane coil pack takes too much amperage for the electronic distributor controller.
You should use a coil system of no lower than 0.84 ohms.
Posted on: 2010/3/13 20:19
From Brisbane, Australia
I also have one from mal, it runs fine now for a couple of months. I still have the resistor in with it. Tacho is hooked up across the resistor.
Hope the info helps.
Geoff
Posted on: 2010/3/13 22:25
